Fastest way to change the oil filter
Discussion in '5th Generation 1998-2001' started by deltaRR, Sep 13, 2023.
  1. deltaRR
    deltaRR New Member
    Hey all,
    I've read from other forum members that oil filter can be changed the fastest by only removing the front inner half cowl (fairing in front of the exhaust headers).
    However, with the hex screws & philips screws removed from that cowl, the cowl still doesn't come off from the black trim next to the cowl & the colored side fairing.
    How do you remove the inner cowl without removing the side fairing?
    For reference, here's an image from the service manual that removes the side fairing afterwards instead of before the inner half cowl. This discrepancy made me question if side fairing simply had to be removed to change the oil filter.
    Thank you,
  2. bmart
    bmart Insider
    Charlotte, NC
    You can do a lot by bending the bodywork a bit...but why? Are you limited in how long you have to do oil changes where you live? :band:
  3. mello dude
    Romania
    Jeez, pull the left side fairing, what, 5 minutes tops?
    Terry Smith likes this.
  4. vfrgiving
    vfrgiving New Member
    deltaRR likes this.
  5. bmart
    bmart Insider
    Charlotte, NC
    I will add this, specific maintenance items are "bigger" than just that. You should take a look around and check for leaks, loose fitting, rubbing hoses/wires, etc. while you can see everything. You wouldn't believe the things that we see at tech inspection on track days...
    deltaRR likes this.
  6. deltaRR
    deltaRR New Member
    You guys are right. It looks like the left side fairing will simply need to come off.
    It indeed doesn't take too long after all.
    Nonetheless, thanks for responding so swiftly.
  7. deltaRR
    deltaRR New Member
    Good call. Having an electric driver is definitely a good idea.
    Only caveat is being careful not to overtighten since it's harder to feel the resistance compared to hand tightening it.
    Definitely. Thanks for the reminder. It'll be good to check for other maintenance inspection items from the service manual while there's easier access with the side fairing off.
  8. vfrgiving
    Those low voltage screwdrivers don't generate that much torque. You'd really have to be not paying attention to break something. If you have a 1/4" impact driver, keep that far away from the bike.
    Another tip I didn't invent, fold up a square of some aluminum foil and place it below the filter covering the header pipes and aim it towards the collection pan. That way oil won't coat the header pipes when you remove the filter.
    deltaRR likes this.
  9. Frosty
    Frosty New Member
  10. bmart
    bmart Insider
    Charlotte, NC
    I know they have a big following, but from a logic standpoint, I don't understand putting two seals where one seal is and calling it an improvement. :)
  11. 50th VFR
    50th VFR Member
    Scotland
    Remember all cross head screws on Honda's are JIS and not Philips or Pozi.
    Invest in a No1 and No2 JIS screwdrivers, you will have much more success in getting screws out and do far less damage to screw heads.
