Fan won't come on....
Discussion in '1st & 2nd Generation 1983-1989' started by Rapidroy, Aug 20, 2007.
  1. Rapidroy
    Rapidroy New Member
    Albuquerque, NM
    so I jumped the thermostat switch at the rad. and the fan came on. So I'm thinking its got to be the switch. What do ya all think.
  2. eddievalleytrailer
    eddievalleytrailer Member
    Jonesborough, TN
    Might be a bad temp sending unit (switch). Is the radiator getting hot enough to turn the fan on? Could be bad thermostat or radiator cap if the radiator isn't getting very hot.
  3. Rapidroy
    Rapidroy New Member
    Albuquerque, NM
    The Rad. was very very hot (couldnt touch it) then it started to puke green stuff out the overflow. The volts on one side of the switch was 12v on the other side was .5 of a volt if any. I thought that when the switch gets hot it closes and passes 12v though to the fan relay which kicks the fan on.
    Roy
  4. DANIMAL
    DANIMAL New Member
    Metairie, LA USA
    Roy,
    fan thermostat switch closes when temp reaches 220 degrees F it grounds the fan motor and makes it run. Switch is most likely the culprit. Did you recently flush radiator? if so you may have air trapped in cooling sys. air is a poor conductor of heat
    to bleed air out of system you need to open radiator cap and snap throttle open quickly reving to 4-6 thousand RPMs be sure engine is warm and that thermostat is open ~ 15 min
    hope this helps
  5. eddievalleytrailer
    Jonesborough, TN
    Sounds like a bad sending unit (switch) to me. I'd replace it and add a manual switch, so I could turn it on whenever I want. That's what I did.:biggrin:
  6. masonv45
    masonv45 New Member
    Here is info. from the notes I have:
    Fanstat
    Auto Tune PT2628
    ACDelco E-1858
    Beck/Arnley WorldParts 201-0817
    201-1369
    BWD (Borg-Warner) TFS500
    Echlin (NAPA) FS-130
    Facet FS8404
    Filko TFS-1
    Four Seasons 35934
    G.P. (Sorenson) 40-5001
    Kem TW-65
    Mitech TS-84
    Motorcraft no interchange
    Niehoff WA-639B
    Standard TS-84
    Wells SW-504
    Asking for a thermo fan switch to fit a 1983 Honda Accord at your local auto
    parts store should net you one of the above numbers.
    This switch fits many Honda car applications, 1975-1991 Honda Civic All 3 door (hatchback) and CRX models also 1986-1991 Acura Integra, all engine sizes
  7. Rapidroy
    Rapidroy New Member
    Albuquerque, NM
    Hi All
    Just installed a NAPA fan switch (FS130SB) and so far its working great! My temp is holding right in the center of the gauge. The Napa switch is a lot larger but fit just fine. I made a couple of jumper wires to change the barrel plug to a spade so I did'nt need to cut any factory wires. Just a nice and clean insallation.:cool:
    Thanks for the info.
    Roy
  8. midias
    midias New Member
    Rochester NY
    I know where you got that list because I gave it to him. :)
  9. biz
    biz New Member
    Does anyone know if these switches will work for an 84 VF700 sabre? My Fan is not coming on at all. I will try to pull the fan off and see if I can get it to come on manually.
