evap canister routing question
Discussion in 'Mechanics Garage' started by hoodoshnik, Aug 10, 2015.
  1. hoodoshnik
    hoodoshnik New Member
    maine
    hi,
    hoping someone can help wi a 2007 6th gen question - the larger hose connection on my fuel evap can is missing. The small one routs to the tank like it should, but I dont see where the larger one must have connected back into the throttle bodies or wherever. Theres no hose there at all to help figure it out ...
    i dont see a "evap purge control valve" as on the CA models as shown in the manual pg 39 either...
    or is mine the bottom diagram on that page that just has a hose going from tank to can and then one going out clipped next to the gas and water overflow? seems useless...
  2. hoodoshnik
    maine
    heres the page
  3. VFR777
    VFR777 New Member
    Kansas
    I totally removed my evap canister a long time ago....
  4. hoodoshnik
    maine
    so it does nothing except in CA where its routed back into the throttle bodies?
  5. VFR777
    VFR777 New Member
    Kansas
    I would reckon not, but I will let others chime in....
  6. Mark919
    Mark919 New Member
    Detroit Suburbs
    All 6th gen. models are the same. All are 50 state legal.
    Large canister hose on the right runs to the evap purge control valve (which mounts to the middle 12mm engine frame bolt). If the purge control valve is missing then the canister is not functional (can be removed since the system no longer works). Hopefully the person that removed the purge control valve properly plugged the hose going to the throttle body 'T'.
    The line to the canister can route over to the left side of the bike with the other tank drain line.
  7. hoodoshnik
    maine
    Thank you!
  8. haygood
    haygood New Member
    Route the whole assembly straight to the dumpster. Ha!
  9. sunofwolf
    sunofwolf New Member
    the first thing I did was junk this unit-one line from the gas tank is over flow for gas tank-that needs to vent-the other two is plugged.
