engine oil question
Discussion in 'Mechanics Garage' started by hassangh, Jul 26, 2012.
  1. hassangh
    hassangh New Member
    it might be simple to some of you, but not for a mechanically uninclined person like myself, i need to ask
    i got some rotella t6 to add to the vfr, but its viscosity is 5w-40
    does it make a difference if i used it in my vfr800 '06?
    whats the main difference between 10w-40 (besides weight)?
    if i cant use it, why not?
  2. OOTV
    OOTV Member
    Typically the hotter the climate the higher the viscosity i.e. In Arizona, you would probably use something more like 20w-50. Where as cooler climates, Canada for example, you would use a lower viscosity i.e. 5w-40. But the actual current climate should dictate would you might want to be running now. Thinner oils for colder climates, thicker for warmer. That's the simplest explanation I have.
  3. hassangh
    hassangh New Member
    so i should be ok if i use 5w-40?
  4. OOTV
    OOTV Member
    According to the Honda Service manual for 2002-2009 models the recommended oil viscosity is 10w-40. That being said, I personally have used a different viscosity oil than what was recommended in some of my other vehicles without issue, but I always tried to use what's recommended if at all possible. Sometimes I would use 20w-50 in the summer an 10w-40 in the winter (So Cal doesn't get really cold). I would imagine that as long as you do not under fill or over fill your motor you shouldn't have an issue. I think what is more important to note is the service classification, i.e. API service class and JASO (see image below)
    Also see... Motor oil - Wikipedia, the free encyclopedia
    Cheers
  5. bitterpil
    bitterpil New Member
    Northern Virginia
    Yer fine.... Done! Now put it in your bike and ride.
  6. hassangh
    hassangh New Member
    lol now why didnt i think of that!!:tongue:
    Well said and YES!!!:rambo::rambo:
  7. TOE CUTTER
    Your good....ride it like you just stole it.
