Electrical Problem / no power to anything
Discussion in 'Mechanics Garage' started by cjheap, Aug 12, 2008.
  1. cjheap
    cjheap New Member
    I am not getting any power to anything. Turn the key and nothing lights up, no horn, no starter.
    I checked the starter relay and have power to the harness after the relay.
    Is there a main fuse / Relay on a 91 ?
  2. WhiteKnight
    WhiteKnight Well-Known Member
    London, Ky
    There is a 30A fuse next to the battery box.
  3. cjheap
    cjheap New Member
    That is the plug / fuse for the starter relay.
    That four connector plug is the problem.
    Any Idea on a fix that does not include replacing the harness? The relay has a four spade male connection and the faulty plug is four female.
    . __ __ .
    . __ __ .
  4. masonv45
    masonv45 New Member
    You can insert a paper clip end to push back the metal tang and remove the spade from the molex connector. Inspect it, clean it off and push it back in. Do this with every connector.
    If you want to replace the entire connector, you can try here: Vintage Connections: OEM-Style Connectors for Japanese Motorcycles
    There are many other sources out there...
  5. cjheap
    cjheap New Member
    thanks for the link. I will see if any of them will work.
    Where is a good place to buy a battery?
  6. squirrelman
    sears automotive or walmart...
  7. eadc
    eadc New Member
    Washington, DC
    I had this problem back in June. The four plugs on the starter relay were coming off of the housing (rust / corrosion). I replaced that, but it didn't fix the problem. Turns out the connectors were fried, too (even after cleaning w/steel wool). I ordered some from here:
    Wire My Bike
    He sent four heavy duty wires, connectors, some solder (which we didn't need it turned out) and it worked like a charm. It wasn't expensive, and not a hard fix.
    good luck.
