electrical diagram vfr 750f '86?
Discussion in 'Mechanics Garage' started by d_vfr, Sep 17, 2012.
  1. d_vfr
    d_vfr New Member
    i am looking for an electrical diagram for a vfr 750f (1986). i can't read out the one in the download version of the service manual, does anyone have a better scan? i need to wire in an alarm unit.
    Just pick up a power lead from the battery through an additional in-line fuse.
  3. d_vfr
    d_vfr New Member
    there is a little bit more to wire in, it is a datatool.
  4. TOE CUTTER
    Can barely read the original, doubt any copy will be readable. Got some specific things your looking for?
  5. d_vfr
    d_vfr New Member
    the alarm needs wires to / from:
    a) 2 * ground
    b) 2 * 12 volt sources
    1) the turn signals
    2) engine cut
    3) starter cut (wire in harnes from to starter solenoid)
    3) 12 volt positive ignition switched (prevents the alarm being armed when the engine is running).
    i am not sure if i will wire the engine cut, not sure what possibility the vfr has.
    for 12 volt ignition switched, i don't believe i can use the commonly used light circuit? so i will need to source an ignition powered 12 volt near the fusebox.
    any help is appreciated
