Electric problem-please help
Discussion in '6th Generation 2002-2013' started by Sudsemnatu, Jun 2, 2010.
  1. Sudsemnatu
    Sudsemnatu New Member
    Romania
    Hi,
    I'm writing from Romania with a strange situation at my VFR. Not strange for someone but for me...
    So...I have a VFR 2002 with some electrical problems. Last summer in one day, when i put on the lights the engine stops...i go to a mecanic, saw the problem - the bulb from the rearside...and everything was ok.
    Now...last week...i start the engine...start the lights...and the engine stops. Tried to restart the engine..fails. Turn off the lights..the engine stats....but now i don;t have no lights HI AND LOW headlight. I only have sidelights. When i put the signal...the sidelights gones crazy.
    Please help...what should i verify first? Someone have the electrical scheme for VFR 2002 without ABS--maybe coloured? Should i command something from the ebay?
    I'm desperate !!! :(
  2. Sudsemnatu
    Romania
    Nobody??????
  3. Bubba Zanetti
    Bubba Zanetti Member
    Delaware
    Most of us are still in bed in the US.
    Give us about 12 hours and you'll get an answer.
    BZ
  4. Sudsemnatu
    Romania
    Ok mate
    Cheers
  5. Nepix
    Nepix New Member
    Seattle, WA
    im pretty sure the recalls were worldwide...
    has the 2002 wiring harness recall been done on your bike?
  6. Sudsemnatu
    Romania
    I don t know ! i bought the bike from Romania, but she arrived from Italy two years ago. I think nobody was with her at any recall.
    What means the recall ? What did they changed at the general recall? Maybe i have to do the same thing.
  7. Nepix
    Nepix New Member
    Seattle, WA
    check with your dealer to see if there has been a recall on the front wiring harness.
    they check by vin number
  8. dko15
    dko15 New Member
    Northern California
    Not being familiar with the recall yet, first I would check with a Euro spec owners manual. Here in the US, we have our headlight low beams come on as soon as the ignition is on....
    My best guess is that there is a short in the switch or wiring which SHOULD be blowing a fuse, or if that circuit has been vented by using a bigger fuse, then that short could be bogging your alternator which makes the engine die. Just a guess based on my automotive experience. Make sure the fuses installed are correct; not rated too high for the circuit.
