Electric connector
Discussion in '1st & 2nd Generation 1983-1989' started by RS125, Nov 24, 2019.
  1. RS125
  2. RS125
  3. NorcalBoy
  4. Allyance
    Allyance Member
    Germany
    East Bay, California
    Connectors melt because of contact resistance, either from corrosion or contacts are not rated for the current. I see no specifications for current carrying capacity, pins look small, so only good for low current applications.
    raYzerman likes this.
  5. mello dude
    Romania
    MetriPack connectors are good stuff and I have used them myself. If you are referring to the R/R to stator connection, current art is to eliminate the physical connection totally an replace with either direct solder together or a double overlap butt connection....
    I have used the MetriPack 630s in that spot and they do work well for that application too. (Rated 42amps)
    As a btw, ---- www.cycleterminal.com is a great source for motorcycle wiring needs and will be cheaper too.
