EBAY ALERT: VF500F Part Out
Discussion in '1st & 2nd Generation 1983-1989' started by ferrarone, May 7, 2010.
  1. ferrarone
    ferrarone New Member
    Manchester, NH
    UPDATE: ONLY 18 HOURS LEFT
    I just got a 3rd parts bike for my VF500F project and went from having some parts I had no need for, to having a million parts I have no need for. I'm also moving on the 16th so all the auctions are 5 day listings and start at .99 cents.
    Items currently up:
    Fuse Cover - HONDA VF500F INTERCEPTOR 500 IGNITION SWITCH FUSE COVER : eBay Motors (item 260599033237 end time May-12-10 15:12:00 PDT)
    Ignition Units (Both) - 1984 / 85 Honda VF500 Interceptor ignition CDI units : eBay Motors (item 260599035220 end time May-12-10 15:18:07 PDT)
    Speedometer/Tachometer - Honda Interceptor VF500F VF 500F Speedometer Tachometer : eBay Motors (item 260599036200 end time May-12-10 15:21:41 PDT)
    Speedometer/Tachometer #2 - Honda Interceptor VF500F VF 500F Speedometer Tachometer : eBay Motors (item 260599036420 end time May-12-10 15:22:40 PDT)
    Handlebars - VF500F VF 500 INTERCEPTOR V30 HANDLEBARS : eBay Motors (item 260599037552 end time May-12-10 15:26:06 PDT)
    Front Cylinder Head (Damaged) - 84/85 Honda VF500F / Magna Front Cylinder Head w/ Cams : eBay Motors (item 260599039690 end time May-12-10 15:33:11 PDT)
    Fuel Tank - Honda VF500 Interceptor Fuel Tank 1984 VF500f vf 500 : eBay Motors (item 260599040882 end time May-12-10 15:36:30 PDT)
    Shock Absorber - 1984 / 85 / 86 Honda VF500F Shock Absorber : eBay Motors (item 260599046417 end time May-12-10 15:56:42 PDT)
    Ignition Coils - HONDA 1985 VF500 VF 500 INTERCEPTER IGNITION COILS : eBay Motors (item 260597859587 end time May-12-10 16:47:52 PDT)
    Ignition Coils #2 - HONDA 1985 VF500 VF 500 INTERCEPTER IGNITION COILS : eBay Motors (item 260597859783 end time May-12-10 16:48:44 PDT)
    Left Fairing Cover - 1985 Honda VF500F Interceptor left fairing side cover : eBay Motors (item 260597861023 end time May-12-10 16:54:16 PDT)
    Front Fender - Front Fender - 1985 Honda VF500 Interceptor VF 500 : eBay Motors (item 260598334031 end time May-11-10 11:58:05 PDT)
    I will continue putting items up as I go through them and figure out what I do or don't need. If VFR members need anything and want to bypass the bidding and have me mail it out immediately then let me know. Basically I'm selling extras so I can afford the safety gear I need and don't have, like a helmet.
    Items not up on eBay yet:
    Front Forks (Black)
    Front Rim
    Rear Rim
    Entire Frame
    Parts Motor (Dropped Valve, Bad Piston + Head, Good Cylinder Walls)
    Good Motor <- Needs Piston rings or unstuck the current ones
    Piston Rings (5 Sets)
    Used Valves (Within Factory Tolerances)
    Used Springs (Within Factory Tolerances)
    Headlight
    Foot Pegs
    Front Brake Caliper
    Rear Brake Caliper
    Dented Fuel Tank w/ Petcock (No Leaks Painted Purple)
    Front Fender (Purple)
    Good Battery
    Voltage Regulator
    Starter
    Kickstand
    Airbox
  2. Hawkrider
    Hawkrider New Member
    Hampton Roads, VA
    Do you happen to have a kickstand?
  3. ferrarone
    Manchester, NH
    I do, pm sent.
  4. Nati0nalxCrisis
    Nati0nalxCrisis New Member
    Mukwonago, WI
    Do you happen to have the rear fender still? Just the fender, I don't need the blinkers or tail lights/Grab bar.
    thank you.
  5. thebussman
    thebussman New Member
    are you going to part out the carbs?
  6. ferrarone
    Manchester, NH
    Right now i have 3 carbs. 1 dirty but in otherwise brand new condition, 1 old and a little ratty but clean, and 1 clean in good condition but off the airbox and in a bunch of pieces. I think I'm going to use one, ebay another soon, and part out the third. Did you need parts or the entire thing?
  7. ferrarone
    Manchester, NH
    I don't I actually sold it on ebay before I had the idea of posting it on VFR world.
  8. thebussman
    i just need the little lever that holds the idle between the black thumbscrew and the actual butterfly. this is first proity. if you have that I'll also buy a left side mirror, the tool kit, and tool kit lid,
  9. ferrarone
    Manchester, NH
    update: Only 18 hours left
  10. Big3
    Big3 New Member
    Lancaster, Ohio
    good clean taillight?
  11. ferrarone
    Manchester, NH
    Already sold it to a VFR member a week or so ago.
  12. slowbird
    slowbird Member
    Toronto, Ontario.
    Windscreen?
  13. tecnui
    tecnui New Member
    Do you still have the CDI boxes? and headlight assembly? thanks - Jacob
  14. Michael E
    Michael E New Member
    Ottawa, Ontario
    I am interested in the rings, valves and valve springs that you have't posted yet. Let me know when you are putting them up.
