Hi All, Does anyone know if a Ducati 748/916/996 rear sprocket cush drive will fit on the splines of a VFR/RVF400 axle ? Thanks Chris W.
I've now managed to find the bearing sizes & the Ducati shaft is only 35mm OD verses the VFR/RVF400/800 which is 40mm OD, so the Ducati part won't fit. I've done some alternate thinking & will try to integrate the VFR800 inner splined cush drive unit with the Ducati 748/916 etc external sprocket carrier face plate & use a QD sprocket carrier so I can use Ducati sprockets ! Should work if the dimensions are within workable tolerances. :wink:
