Drive chain wear guide(label)
Discussion in '3rd & 4th Generation 1990-1997' started by BicyclePhil, Jul 23, 2009.
  1. BicyclePhil
    BicyclePhil New Member
    SF CA
    After a bit of searching I am coming up empty handed.
    Does anyone know a source for the chain wear sticker, (attaches to the plastic chain guard), used to determine chain stretch(pass/fail)?
    Alternatively is their another method to determine if a chain has stretched too far?
  2. ThickToast
    ThickToast New Member
    Springfield,Illinois
    Have you tried BAbbittsonline.com?
  3. 34468 Randy
    I ordered one from the dealer. Somewhere around $10.00. But it was a different size than the original so I don't know how accurate it is.
    BTW, that has nothing to do with the chain. It is a gauge to measure the wear on your sprocket. To measure your chain, bike on centre stand, chain rotated to its flattest spot in the centre between the two sprockets. And the sage or tension should be somewhere between 1/2 and 1 1/2 inches. Some will say you should have equivalent to your own weight on the bike while you are doing this. I dunno about that but it does make sense seeing as ideally, you will be riding this thing when you are most worried about chain tension.
  4. Scubalong
    Randy, I think Bicyclephil want to know when his chain is toast, When the chain is max out of adjustment and nolonger safe to ride with.
  5. turboguzzi
    turboguzzi New Member
    pull on the chain on the back side of the rear sprocket, at the 3 o'clock area, if chain lifts off the sprocket so you can see half of the tooth or more, then its gone
    TG
  6. karazy
    karazy New Member
    Halifax, Nova Scotia, Canada
    As you can see, if the sprocket is past the tab on the guard, it is time to replace the "chain" and sprockets.
    :crazy:
  7. hoss8640
    hoss8640 New Member
    Holland MI
    bikebandit.com should have that label
