Drive chain #s
Discussion in '5th Generation 1998-2001' started by jobvfr, Oct 13, 2008.
  1. jobvfr
    jobvfr New Member
    Princeton NJ
    I need to replace the chain on my '01, and I am thinking about different gearing as well. I would like the bike to rev out a little quicker and to pick
    up some revs in low speed corners. I'm also thinking about converting to
    a 520 chain, but I'm sure there are drawbacks. (chain life, o-ring vs non o-ring etc.)
    Any advise would be welcome
    JOBVFR
  2. KC-10 FE
    KC-10 FE New Member
    You will just fine with 530, 525 or 520. If you want to change the gearing specifically for off the line performance, go 1 down on the front & 2 up on the back. Naturally, the 2 drawbacks will be lower MPG & increased rev's at speed.
    KC-10 FE out...
    :plane: :usa2:
  3. Action
    Action New Member
    Albuquerque
    This Kit is on its way from Sprocket center -
    D.I.D. 530VM X'ring Chain & Steel Sprocket Kit - Honda VFR 800F 02-08
    I like DID chains, 19.7K on the current one. I went +2 on the rear to give me a little more low end grunt but still be able to cruse on the slab.
    Action
