Draining the coolant
Discussion in 'Mechanics Garage' started by gen, Aug 9, 2008.
  1. gen
    gen New Member
    Bay Area, California
    I just bought the water wetter product and before i can use it, i have to drain the old coolant. how do i do this? thank you very much.:unsure:
  2. drewl
    drewl Insider
    Virginia Beach, Va
    The water pump is located to the front of the clutch on the left side of the bike. There is a drain bolt on the side bottom. Open the rad cap and then the drain plug. Stand back it comes out quick.
  3. speed
    speed New Member
    Harbor Oregon 97415
    drew, you should be getting good at that about now ?
  4. GreyVF750F
    GreyVF750F Member
    West of Cleveland Ohio
    Suggestion: Don't use anti-freeze with the water wetter. Just distilled water, rust inhibitor and WW. Otherwise your motor will most likely run hotter. Unless your cooling system is big enough to cool the added heat. Glycol holds and maintains the extra heat and it's harder to cool the motor. So says the maker and I've experienced the same.
  5. gen
    gen New Member
    thanks guys!
  6. derstuka
    San Diego, CA
