Does the install of Leo Vinse pipes require a power programmer?
Discussion in '6th Generation 2002-2013' started by duke, Aug 10, 2010.
  1. duke
    duke New Member
    Hello all,
    I am new to the forum but have been reviewing posts for a while. Looks like alot of good info to be found.
    For those who have installed the Leo Vince Evo II exhaust recently I have a question. How does the bike run with the stock ECU?
    Thanks in advance for the feedback.
    Duke
  2. havcar
    havcar New Member
    Denver CO
    The Leo, as with any other aftermarket pipe, can be installed without a fuel management system. Unfortunately the stock ECU will not operate the bike at optimum, usually it's not even close. This is especially true on the 6th gen models, which don't have a particularly good map to begin with. I would say that if you're going to pipe it that the extra $300 for a PCIII and o2 eliminators is worth every nickel as is a dyno tune. If you are in fact on a 6th gen you won't be disappointed. It handles everything from off-idle surging, to the major power drop at 5400rpm, and smoothing out the VTEC transition. You'll probably realize a small gain in HP aswell.
  3. duke
    duke New Member
    Thank you for the input. My goal is to improve the exhaust and performance of the bike without getting too far away from stock.
    This bike is more of a daily driver/tourer than track day bike.
    Happy riding
  4. tpadden
    tpadden New Member
    Woodbridge, VA
    i've had my leo's on for about 2000 miles and it runs fine without a powercommmander or the o2 eliminators, though i eventually plan to replace them. I havn't noticed any popping on decel but the bike is herky jerky sometimes at low rpm's but it was like that before i put the pipes on. A power commander with a custom tune will solve the jerkiness and provide optimum performance.
  5. ratbiker
    ratbiker New Member
    Dorset UK
    Have you guys not done the small 5 min air box mods to smooth out the bike at lower revs?
    Mine has Leo cans and runs like a dream.
  6. Kobe Diesel
    Kobe Diesel New Member
    CT
    my $0.02 = suspension upgrade, air box mod, 02 sensor bypass, semi-gut exhaust cans. invest your money where it matters most - suspension.
  7. tinkerinWstuff
    All I know is, I've rode with havcar a couple times in groups of 15-20 guys. The liter bikes ride around behind him. If I bought 6th gen, he'd the the first guy I talked to. No disrespect to anyone else, just saying, if havcar says something I'll believe him.
