Do you plug in the battery tender to the plug-in or directly to the battery.
Discussion in '8th Generation 2014-Present' started by amoreira88, Sep 30, 2016.
  1. amoreira88
    amoreira88 New Member
    Phila, PA.
    How do you tell if it is working?
  2. Jeff_Barrett
    Jeff_Barrett Member
    Winnipeg, MB
    The only time I use the tender is during the winter months.
    I pull the battery out and bring it inside since I can't ride with snow on the ground anyways. There is an LED indicator light.
    I advise against leaving it on for extended periods, even with the advanced charging circuitry I've seen it degrade a battery. Just plug it in for a day once a month in the winter if that's how you use it.
  3. OOTV
    OOTV Member
    Based on the thread title, it would appear that you are trying to plug the battery tender into some sort of plug on your bike? Most battery tenders come with a pig tail that attaches directly to the battery and has an SAE connector on the other end. This usually mates up with the end of the cable off of the battery tender itself. Some kits have an SAE to spring clamps, which would be for momentary connections, like doing a quick charge on a free standing battery or on someone else's bike without the SAE connector.
    Most battery tenders (Name Brand) have an LED that changes color when charging and when the battery is charged. Generic models make have similar indicators but ultimately once a battery is fully charged, taking the tender off is up to you.
  4. Nelix
    Nelix New Member
    Paisley
    Plug it in directly on a very long lead and this will give you a petrol/electric hybrid VFR. Just be sure to retrace your route exactly or you can get tangled up.
  5. amoreira88
    Phila, PA.
    [​IMG][​IMG]
    You're bike doesn't have a plug? Is this not factory?
  6. DriverDave
    DriverDave New Member
    Denver, CO
    No, it does not come from the factory with that plug...Not exactly difficult to install one, however.
    Did you get your bike new or used?
  7. GigemVFR
    GigemVFR New Member
    TEXAS
    No, that is not factory plug but looks like someone had put one on there to use with battery tender. The light on tender tells you status of charger. Go here and click on the charger you have and then the "Documentation" under the picture and it gives you the instructions if you don't have. Tells you what the different color lights and whether they are flashing or not and what each means.
    http://www.batterytender.com/Motorcycle/
  8. OOTV
    OOTV Member
    My bike does have that plug and is the one I described in my first post as the pig tail with the SAE connector, unfortunately this is not a factory installed item. The PO of my bike put the one I have on.
  9. amoreira88
    Phila, PA.
    Wonder if the dealer put it on. Cause I am the first owner just got it in may
  10. OOTV
    OOTV Member
    That sounds like the most likely scenario. If it sat on the show floor, they may put these on so they can keep the battery charged and ready to go.
  11. amoreira88
    Phila, PA.
    Here I am thinking this bike comes with everything haha. I mean it did but I thought it was stock. Still good to know it isn't. Thanks everyone
  12. NorcalBoy
  13. Ghost_Rider
    Ghost_Rider Active Member
    LA & Utah
    Funny, I have heard about the degradation, however, my experience has been just the opposite with a battery tender over the last 20 years. Seeing as how most of my MC batteries (even a Walmart battery) last more than 5 years, it seems to work for me! YMMV.
    Btw, I keep it plugged in whenever it sits in my garage unwritten.
