Cutting open a fuel filter
Discussion in 'Mechanics Garage' started by signal, Sep 10, 2013.
  1. signal
    Any issue with taking a dremel type tool to a fuel filter to cut it open and check it out? I just had mine replaced and I would just like to see what it looks like inside, I'll even post up photos but I don't want to catch on fire, so wasn't sure if it was smart to take a dremel type tool to it. Anyone know?
  2. just phil
    just phil New Member
    Peterborough,On,Canukistan
    I'm guessin' you could probably rinse it out or something. And maybe keep a fire extinguisher handy...:kaboom:
  3. squirrelman
    Cut through one of the endcaps and pull out the element, spread out input side pleats for inspection. What you see there is what's floating around in the tank.
    Without fire mankind would still be in the stone age, so be brave, Bunky, and just dive in !
    Extinguisher, Phil ?? Sometimes extinguishers cause more damage than they cure. :nelson:
  4. just phil
    True... But they can be fun to use...
