Cut chin strap
Discussion in 'Gear & Accessories' started by RobVG, Sep 22, 2015.
  1. RobVG
    RobVG Member
    White Rock BC
    I got alot of extra chin strap. I want to cut it off but just wanted to check if there' any reason not to- can't put it back on.
  2. Terry Smith
    I can't think why making it shorter would matter; more important that it stops beating your neck while riding. You could heat the fresh cut end up to melt it a little and stop it fraying.
  3. 34468 Randy
    Why are you wanting to cut the strap? All helmets I have had, the loose end of the strap colds back after going through the D rngs and attaches back on itself with a dome fastener. No flapping aroind at all.
  4. RobVG
    RobVG Member
    White Rock BC
    Yeah Randy, like Cadbury said, it flaps. It had a magnetic button but like the reviews said, it falls out right away.
    Bell Revolver
  5. fatbastard
    fatbastard New Member
    NSW Norah Head
    Have you considered just having a 5mm press stud fitted ? Most alterations shops would do if for a few bucks. They can be stitched on or pressed through the tape, although that might be hard to do on the loop with the D rings through it. It's pretty easy to do, it's not load bearing and shouldn't weaken the tape. A short strap will tend to be prone to slippage in an off and could come undone, plus it will be fiddly to try and tighten up unless you leave some tail which may then be too short to tuck away.
  6. 34468 Randy
    Or. A little piece of Velcro. That's Canajun ya know!
  7. Badbilly
    So, would some of these fixes work on shoelaces too?
