Custom Datel Voltmeter
Discussion in 'General VFR Discussions' started by Britt, Feb 22, 2010.
  1. Britt
    Britt New Member
    Westmont, IL
    I've been looking for a voltmeter, and ran across a BMW owner who built his own that I liked a lot..... so I figured I would replicate his work. I rarely ride in the dark so I don't need an LED unit. I was interested in LCD, and the Datel works great for my needs. And I didn't want to cut up my dash so it had to be a surface mount unit.
    I bought a BUD Potting Box (part number: 563-PB-1558)....
    .... a BUD potting box cover (part number: PBC-1558-CN)....
    ..... and a Datel LCD digital panel meter (part number: 20LCD-1-DCM-C).
    All were from from Mouser Electronics and arrived extremely quickly - Mouser Electronics - Electronic Component Distributor
    I carefully measured and using a razor, cut an opening for the unit in the potting box.
    The Datel unit slipped right in.
    I used 5 minute epoxy around the edges of the Datel unit to hold it in place as well as waterproof it. I took a charger from an old Nokia phone, cracked open the transformer to get at the wires, cut off the other end, and wired that to the terminals on the Datel unit. I used my multimeter to compare voltages at the battery and used the adjusting screw on the Datel unit to calibrate it. Cut a slot to fit the cord through, epoxied it in place, and then epoxied the potting box cover on the back of the potting box. I am fairly confident that water cannot get into the box.
    I mounted the box to my dash with 3M Dual Lock velcro.
    Here is the meter with the engine warmed up and idling:
    Here is the meter at 3000 RPM:
    I have found my voltage readings to be very consistent at any RPM over idle (pretty much 14.7 volts at any RPM above idle). I purchased a VFRness but have not installed it yet. Maybe I won't need to but now I feel better about being able to keep my eye on my electrical system.
    Credit for this project goes to: Surface Mount Datel LCD Voltmeter Install Thank you!
  2. Deadsmiley
    Deadsmiley Insider
    Bowling Green, KY
    I like it! Thanks for the write up.
  3. Britt
    Britt New Member
    Westmont, IL
    Scratch this idea!
    I washed the bike the other day and barely got the LCD screen wet... and suddenly it's showing that my bike is only putting out 9 volts. Once it completely dried out, it consistently shows that it's getting over 15 volts. My multimeter tells me that my custom voltmeter is lying to me...
    Oh well, it was a $30 learning experience!
  4. Mark 024
    Mark 024 New Member
    Sydney, Aust
    Pity,
    I was just thinking about doing the same thing.
    I didnt like the idea of cutting into my dash.
    Perhaps silicone sealant would be a better option.
    Have you just done away with it??
  5. Britt
    Britt New Member
    Westmont, IL
    I ended up selling my VFR so I'm not sure how it held up. It seemed to be working okay at the time that I sold it, but I suggested to the new owner that he keep it dry.
    I think that the problem was that water got in between the LCD screen and the housing it came in, and I don't know that you can easily take that apart without damaging it. After going through the exercise, if I were doing this again I would just spend a little more for something waterproof...
