cush drive?
Discussion in 'Mechanics Garage' started by david.vfr, Jun 19, 2008.
  1. david.vfr
    david.vfr New Member
    Kennesaw, GA. just north of Atlanta
    I have a 1999 VFR and from dead start I get a "slipping", "surging" feel until I reach 3000 rpm and it smooths out. Anyone know the cause? How can you tell if the cush drive is bad?
  2. Rangerscott
    Rangerscott New Member
    Texas
    Believe thats the "flat" spot in the ecm fuel mapping. Mine does it. Not much when I have my powercommander hooked up.
  3. porcupine73
    porcupine73 New Member
    I have an '07 and I feel that a little bit too. First gear seems relatively high to me in this bike, and letting the clutch all the way out too early well she definitely doesn't like that.
  4. david.vfr
    That sounds fair. I could not duplicate the problem while riding. Only below 3000 rpm from stop. Thanks for your input!
  5. woody77
    woody77 New Member
    Palo Alto, CA
    under 3000 rpm??? funny, never been down there since I started riding it. I rev to 3K and hold it there as I let out the clutch, unless I'm moving it around in a lot or something else where I'm keeping my feet down. But then, I'm probably being rough on it, too.
