Cracked Radiator VF500F
Discussion in '1st & 2nd Generation 1983-1989' started by ridinclassic, Aug 31, 2015.
  1. ridinclassic
    ridinclassic New Member
    Ames, Iowa
    There is a small leak in my radiator and i was wondering what kind of options i have to replace it? All i could find upon a quick google search was used ones. Thanks for all help.
  2. mattoehler
    mattoehler New Member
    Once upon a time there were things called radiator repair shops. If you could track one of those down they might be able to help. Says you are in Iowa, the twin cities might still have a few around if you look up there. Unless you want a new one, can always try the local Honda dealer. Best of luck!
  3. squirrelman
    I've had a JBweld patch on a VFR radiator for years, no leaks, no problems.
