Cost of a 16K service for 8th generation VFR800
Discussion in 'Mechanics Garage' started by IOPS5, Oct 31, 2025.
  1. IOPS5
    IOPS5 New Member
    I was quoted in 2025 $3100 for a 16K service including $1750 for 10 hours of a technicians time to check the valves. Is this a reasonable estimate because 10 on-the-clock hours seems like a lot of time?
  2. mello dude
    You are asking a group of high skill DIY tech guys...
    mike alexander likes this.
  3. Thumbs
    Thumbs Member
    Bath(ish)
    10 hours is long time, too long for just a VETC check and adjust, who’s doing it for that kind of money, Batman?
    FWIW I paid Fowlers £800 for the 16k check in 2017
  4. Terry Smith
    It took me about 2 hours per cylinder head, and I am far from a professional. That gets the standard valves checked, the cams out and VTEC stoppers in, cams back in, VTEC clearance checked, cams out to remove the stoppers, and then cams back in. But...if the VTEC valves are out of spec, you need to buy new cam buckets, and that might delay the rebuilding process unless they have stock, and they are costly (I needed 7 @ USD25 each).
  5. mello dude
    Adding to what Terry said... At 16k it's highly doubtful any valves are out of spec.... Probably fine to wait to 32k for a check...
  6. Thumbs
    Thumbs Member
    Bath(ish)
    The 16k valve check was changed to 24k some years ago
    Viffer J and Terry Smith like this.
