Cornering '95 VFR750
Discussion in '3rd & 4th Generation 1990-1997' started by WillemK, Aug 24, 2015.
  1. WillemK
    WillemK New Member
    Eys, Limburg
    Hey all,
    I'm getting more used to my bike and cornering is improving. But I don't feel completely comfortable when cornering fast. The rear feels a bit sloppy. It's like it wobbles a bit. The suspension is set to a little above normal with the damping and pre-load. Tire pressure is fine. Is this normal for the bike? The steering head is a little worn and will be replaced next week. Could the steering head be the problem?
  2. V4toTour
    V4toTour New Member
    rear wheel bearing toast? get the tire off the ground and see if there's any play side to side. check the swingarm pivot while you're at it.
  3. safetypro10
    safetypro10 New Member
    Dallas, TX
    Head bearings?
    Shock condition?
    Standard or different (front or back) heights?
    I find adding about 3/4" to the rear enhances cornering feel, all other things correct.
    Larry
  4. squirrelman
    Old, hard, worn-out tires would be the #1 factor.
  5. RVFR
    I'd need to see i,t then ride to be able to tell you..... just saying..... the above posts are pretty much spot on
