cooling temperature light?
Discussion in 'General VFR Discussions' started by Grizzly789, Jun 21, 2007.
  1. Grizzly789
    Grizzly789 New Member
    New Brunswick
    I was checking my owners manual to see if the coolant temperature warning light should come on momentarily when turning the key to the on position to perform a lamp check. It seems there is no lamp check function. I just figured that something so important should be tested to ensure it will work if it was needed. The only explanation I can think of is that this indicating light is redundant due to the digital temperature display that will flash when a high temperature is reached. So the question comes to mind, why bother putting a high temperature light on the dash in the first place? :confused:
    By the way.... this is about a '05 model
  2. masonv45
    masonv45 New Member
    There is a reason they're commonly referred to as "Idiot Lights" . . .
