Coolant temp.
Discussion in '5th Generation 1998-2001' started by Guest, Dec 1, 2005.
  1. Guest
    Guest Guest
    What should the coolant temp. be on a cool day (35 degrees)? My coolant temp. was between 132 to 135 degrees. Isn't this too low? Thank you , Bryan
  2. CAMBIS
    CAMBIS New Member
    OCEANSIDE, CA.
    your thermostat starts opening about 175 degrees. this would be your lowest temp after your motor has warmed (less than five minutes) if your thermostat is stuck open (most likely) hopefully it is stuck all the way open, otherwise in warm weather and riding hard the restriction will cause your bike to run very hot! i know because this is the way mine is now. i bought the new thermostat at the dealer for $35. and after finding out where its buried i checked with the dealer and they want $200 to install it. faulty thermostat seems to be a common problem.
  3. stephanon2whls
    stephanon2whls New Member
    The 1st State.
    Oh yes... The thermostat... what a joy to replace.. They couldn't have buried it much deeper...
    Mine went at about 14000 miles
    Here is my post from many moons ago on the VFRlist:
    Date: Sat, 9 Aug 2003 12:01:42 -0400
    From: "stephanon2whls" <stephanon2whls@xxxxxxxxxxx>
    Subject: 2000 VFR T-stat R&R - long
    Thanks to those that responded to my original T-stat inquiry....
    Here is the offending $26.44 part:
    <image missing>
    I finally got the T-stat and housing O-ring last night - one week after
    ordering it from Anderson Sales/Service in Bloomfield Hills....
    The next issue was - what coolant to use as a replacement ??  The Honduh
    dealer wanted $3.59 +tax per QUART of premixed 50/50 Honduh coolant.  Day
    schmoke da good weed mon.  OK, so now I was on the quest for some high
    quality non-silicate coolant for less that $14.36/gal +tax...  Both of the
    MOPAR coolants I use at work and in my cars contains silicates which Honduh
    claims could be abrasive and damage seals/impeller, etc.  If it's so bad for
    those parts, why don't the automobile OEM's avoid them ??  Dunno, but I do
    know that the Prestone 5/150 'DEX-COOL' orange coolant claims it does not
    contain silicates.  $12.50 later for the Prestone and some 'purified' water
    I was headed to the 'VFR workshop'.  (Incidentally, the 'purified' water was
    not approved for human consumption - what's up with that ??)
    OH, and BTW, just in case you didn't know, the orange (5/150) and green (3
    year) coolant forumulae are in no way compatible with one another.  To
    change from one coolant formultation to another you have to completely flush
    your cooling system thoroughly.  Otherwise, they 'SHOULD' be compatible with
    all cooling systems requiring ethylene glycol based coolant.  Check for
    yourself - I'm not an expert.
    OK, so FSM laid out, I love how you have to jump around to different
    sections to dig into the beast... Step One: Disconnect Battery - See section
    X-XX, Step Two: remove fuel tank - See section X-XX, Step Three: Remove body
    work - See section X-XX  etc. etc. etc.
    Anyway, I started spinning wrenches, and had all the parts laid out and
    'field stripped' for inspection in short order....  If you ever have to do
    this, I don't recommend doing it w/o the FSM... I enjoy a good challenge,
    but putting my VFR together with no torques/instuctions/hints would be a bad
    idea - especially with the myriad of hoses and E/E connections to make on
    the airbox and throttle body assembly.
    OK, so everything is apart and drained, so I plugged the intake ports and
    breather hoses and rolled the VFR out to the driveway to flush the system.
    I stuck my garden hose in every cooling passage that was available and ran
    the hose until the fluid peeing out all over the place was clean and clear.
    To get all of the tap water out of the cooling system, I tilted the bike
    over on the left side and shook it around - a few more drops came out.... I
    even removed the cylinder drain bolt, but mostly clear water came out.... no
    biggie
    The T-stat housing comes apart easily and low and behold - the t-stat is stuck open.. No amount of jiggling would free it... Oh well.. In went the new one.
    Now, I meticulously re-assembled all of the bits I had flied stripped
    earlier, and buttoned her up - minus the body work in case there was a leak.
    BTW, almost every cooling hose clamp was LOOSE...  If you haven't ever
    checked them, it's a good idea to snug them up the next time you do an oil
    change or something.  You won't get them all as there are almost a dozen in
    the 'V' of the engine alone, but every little bit helps.
    I prepared the 50/50 coolant mixture and filled up the system and coolant
    recovery bottle, then started the bike and blipped the throttle a few
    times...  Looked like everything was A-OK... I closed the rad cap and fired
    up the VFR again to let it get warm and de-aerate...  I had a little scare
    when the temp gage read almost 230 and the wax unit was still holding fast
    idle (now at 3000 rpm) and the T-stat had not opened yet (radiators
    cool).... I shut it off and let it sit a second..... fired it back up and
    within 10 seconds, the T-stat opened - PHEW !  there must have been a good
    sized airpocket on the underside of the T-stat preventing the hot water from
    opening the T-stat....ok, all better now.... temp drops down to 170-180 all
    is well - no leaks.
    I button up the rest of the bodywork and put it away for the night - it's
    10PM - time for a beer (I don't drink when I spin wrenches on my bikes)...
    This morning, I went out for a little test ride to make sure the T-stat and
    fan circuit function properly.... I rode around for a good while and the new
    T-stat appeared to operate fine...  When I got home, I let it idle for a bit
    to check the cooling fan operation... The fan didn't come on until 230
    degrees !!! holy cow... I know why - the fan switch sits in the highest part
    of the left radiator where there is most likely a nice big air bubble above
    the coolant.....  I hope this 'burps' itself out with more riding.
    So, it's all done... From start to finish, he whole job took about 4.5 hours
    of steady working to replace the T-stat. Now that I've done it once, I bet I
    could knock an hour off of that....hehe
    Keep the Shiny side up !
    -Stephan, '00 VFR, Yellow - naturally
  4. Tony Boothman
    Tony Boothman New Member
    Ontario Canada
    Re stat
    Do ou know if the 90-93 VFR's had the same stat?I ride in Canada and would like the temp guage a little higher (no #'s on mine),don't like running cool.Thanks Tony...
