Coolant temp 220-225 at 80mph with ambient air temp stating 109
Discussion in '5th Generation 1998-2001' started by YosemiteVFR, Sep 7, 2008.
  1. YosemiteVFR
    YosemiteVFR New Member
    Sweden
    seem like a normal range? I ask because prior to changing the oil/filter & topping off the coolant (level was at minimum) it was running cooler (around 195-200) in these same or very similar conditions. I searched a bit and found various members with various running coolant temps. The fact that it changed towards the warmer end of the range for me is a little puzzling. Any ideas on why this would be?
  2. Joey_Dude
    Joey_Dude Member
    North Georgia
    That sounds way too warm. In Hotlanta I've ridden in 95 degree weather going 70 mph and the temp guage never goes above 180.
    It sounds like the thermostat has to be replaced.
  3. Wiztigg007
    Wiztigg007 New Member
    Apple Valley, CA
    I live in the high desert and if ambient @ 109deg I run about 192-196deg @ 70-75mph
  4. mello dude
    Romania
    Mine is running strangely warm lately, a bit like yours and my first step is to flush the living shit out of the system. I think there are system cleaners you can buy at Autozone, I'm gonna pony up for some of that stuff. New coolant and see if I need a next step. Its a bit odd yours is running hot at speed. You may have air in the system too, you might need to burp the cross hose in the front of the bike.
    MD
    PS -Last time I was at Yosemite, I got a flat tire at Glacier Point!
  5. YosemiteVFR
    Sweden
    Thanks for the replies, I'll keep an eye on it has I haven't seen it get that high again since. Is the thermostat buried under the airbox on the 5ths?
  6. derstuka
    San Diego, CA
    Yeppers....under the airbox, and the entire throttlebody....not hard work necessarily, but lots of work to get at it.
    Like mello said, you might have air in your system.
    Things it could be:
    Air trapped in system (take off radiator cap when it is running and warm, rev the engine a few times, and you can also burp the hose, by squeeze and releasing it.)
    Old depleted coolant (sludge build up)
    bad/leaking radiator cap
    sticking thermostat
    Improper coolant to water mixture (too much anti-freeze)
    Bent radiator fins
    alignment of the planets
    Michael Jackson catching his hair on fire
    etc, etc....
  7. 34468 Randy
    How about struck by lightning?
  8. 98hondavfr
    98hondavfr New Member
    on a hot day, sitting at a long traffic light..the temp will slowly climb up to 223 degrees before the fans kick on. but riding on the highway im usually right around 200.
