Confirm These Voltage #'s Please
Discussion in 'Mechanics Garage' started by KizerSosay, Mar 24, 2016.
  1. KizerSosay
    KizerSosay New Member
    Charging problems.
    -New battery
    12.7v @ rest...good
    12.1v @ idle......bad
    12.1v @ 5krpm....looks bad right? No charging at all.
    -New Ricks stator
    19v idle (2500rpm) each leg
    64v 5krpm each leg....looks good right?
    -New Ricks r/r (to each yellow stator side wire)
    +probe to +, 0 0 0......good?
    -probe to +, 508 508 545...good?
    -probe to -, 001 001 0......bad?
    +probe to -, 001 001 543 bad?
  2. Scubalong
    19V :jaw:
    Check this thread out
    http://vfrworld.com/forums/showthre...mmon-regulator-Stator-failures?highlight=Rubo
    -New Ricks stator
    19v idle each leg
  3. bigbadbass
    bigbadbass New Member
    NEW YORK
    if your regulator is getting 64V AC in and putting 12.1 DC out, I'd say time to go shopping.
    Stop asking, take action.
    If the Ricks is still in a warranty period, I'd explore return procedure.
  4. skimad4x4
    France
    French Alps & London
    And if its out of warranty you may want to read post # 34 - 41 in the thread linked by Scubalong above. .
    Here we go again the 2016 fried RR season is officially open...
    SkiMad
  5. TOE CUTTER
    A fully charged battery will start to boil over almost instantly at 17 volts, are you saying you have 19 volts at the battery?
  6. KizerSosay
    Toe, not at the battery. Stator puts out 15-19v on each leg at idle and up to 60+ at higher rpm's. The battery never gives more than 12.1v running. I talked to a tech and he confirmed the r/r is a dud. I'm going to get a replacement. Thanks to everyone for helping.
  7. bigbadbass
    NEW YORK
    19? hey Moe, hey Larry
  8. zombie
    zombie New Member
    Guelph Ontario
    Every time I see a post about this I stick my head in the sand and hope I have no issues this year with my 2002 with about 80,000 Km. I really have to read that thread and do some checking...... I really should....... shouldn't I.
  9. Terry Smith
    Sticking a voltmeter on your bike might be more useful than sticking your head in the sand. Just saying...
  10. NormK
    NormK New Member
    At least with a voltmeter fitted you get some warning something isn't right so you don't have to push it home
