Competition Werkes fender eliminator
Discussion in 'New Riders' started by Gunzer, Jul 23, 2008.
  1. Gunzer
    Gunzer New Member
    Western NC
    I am considering ordering a fender eliminator kit from Competition Werkes. The angle of the license plate is the only thing I am reluctant about. Does anyone have a photo of this application after the installation?
    Thanx,
    Gunzer
  2. mello dude
    Romania
    Question for you. Can you operate a hacksaw?
    MD
  3. NorcalBoy
    you don't have the year of your machine listed, but i have a 6th gen and the CW fender elim is a nice piece and the angle is good....it also utilizes the stock license plate light. 20 minute install. sorry man, no recent phots since the fender mod and footpeg mount mod.
  4. stewartj239
    stewartj239 Member
    Syracuse, NY
  5. Carnage
    Carnage New Member
    Terrell, TX
    I have an '07 that I put one on and it looks good. You might need to have someone with small fingers to get the nuts on the back of the bolts that hold the light on. My hands wouldn't fit.
  6. cynyc
    cynyc New Member
    Corydon, IN.
    +1. It looks great on my bike. But I couldn't get the light back on. My wifess fingerss weren't small enough to get it and she's tiny. Plate looks great though.
  7. Gunzer
    Gunzer New Member
    Western NC
    Thanks for all the replys. I ordered the kit from Custom Werkes. I appreciate the heads up on the hard to get to bolts. I read a post from a forum member about this exact challenge. This person used a open end wrench with tape on one end to hold the nut while threading the bolt thru. This made sense to me hopefully it will work.
    Cync, thanks for posting those pics. The mod looks great on your ride, so does your Scorpion exhausts...Badass.
    Gunzer
  8. buzzy
    buzzy New Member
    Hillsboro, OR
    When attaching illuminator light there may be some swearing and beer involved...But final install looks great, worth the trouble :)
    With a little ingenuity and patients you'll get it
  9. Gunzer
    Gunzer New Member
    Western NC
    Thanks for the encouragement Buzz. Beer is a must :strong: for this one I'm sure.
  10. stewartj239
    stewartj239 Member
    Syracuse, NY
    Yes, that was my thread. I posted it in hopes that it would help save some frustation and lots of swearing (I did for 10 minutes before coming up with the solution). Anyhow, it should work out just fine for you. Let us know how it goes.
  11. Dangertohimself
    Dangertohimself New Member
    Sault Ste Marie Ontario
    tip on fender eliminator light put both of the bracket fastening bots through the holes then put the light on before u put the bracket back on the bike, there will be just enough room to get your fingers in to tighten the bolts then to tighten them with a 12mm wrench.
  12. Dangertohimself
    oh and if your canadian u will need to use a metal file to widen the bolt holes in it, either that or drill your plate.
  13. Big3
    Big3 New Member
    Lancaster, Ohio
    what a waste of $70
  14. Faith7
    Faith7 New Member
    North Carolina
    best looking one and the one that fits like glove is on VFRD from Kandian Ken, makes them himself and has VFR cut out in middle of tag
  15. crwoody83
    crwoody83 New Member
    Greenville, SC
    Great tips and I was wondering where you could get one of the kits from Kandian Ken. I guess what I am asking is can you order one online? Thanks!
  16. Faith7
    Faith7 New Member
    North Carolina
    can order on VRFD I know just sign up and pm him
  17. Raymond
    Raymond New Member
    Glendale, AZ
    I have a '04 VFR with it and those little nuts used to install the light housing is very small and difficult to get to, especially when you have to change the bulb! I hands are not big (gloves size is med) and I have a hard time reaching in to locate and then tighten them. If you have a small kid of a female friend with small hands, that will be perfect. It is doable and it turn out nice!!! One caution, here in southern California, I got pulled over because the angle of the plate was too steep, according to the police so I hand-bended the plate frame to flatten it but be careful of the clearance needed for your suspension travel. If you completely straighten out the plate frame and you bottom out you rear suspension travel over a bump or something, your rear tire may come into contact with the plate, just FYI.:smile:
