Clutch Upgrade
Discussion in 'Mechanics Garage' started by AWP34, Sep 20, 2015.
  1. AWP34
    AWP34 New Member
    Has anyone upgraded their clutch on the VFR 800 VTEC
    If so please tell me what parts you purchased, links to vendors , and opinions on clutch smoothness or any type of performance gains.
    Thank you for your time.
  2. Knight
    Knight New Member
    USA
  3. TOE CUTTER
    Not sure what you are after as far as an upgrade but after several failed attempts at beefing up my clutch after the supercharger was installed, due to massive slipping, the best set up by far was the factory clutch with 100lbs springs. It does not shudder as it would before when excessively heated and there is no slipping at all.
