Clutch lever feel gone...
Discussion in '6th Generation 2002-2013' started by blackvfr, Aug 31, 2018.
  1. blackvfr
    blackvfr New Member
    Connecticut
    Rode the 06 beauty a week ago it was fine. Went to ride today clutch lever was a limp noodle. Has this happened to anyone else? If so any info would be great! Put in gear and of course she shut off.
    Sent from my SM-G935T using Tapatalk
  2. FJ12rydertoo
    FJ12rydertoo Member
    Platte City, MO
    No leaks and plenty of fluid in the MC? Possibly got a little low and picked up an air bubble? If levels are good, and
    you don't think you've picked up a bubble, then perhaps the clutch lever seal has left town. Also might check
    to make sure the clutch pushrod isn't stuck in the engaged position, although this seems very, very unlikely.
    Just start at the obvious and work you your way down the list. Probably a fill and flush will get things right again.
