Clutch kill switch keeps on a killin'.
Discussion in '5th Generation 1998-2001' started by Deadsmiley, Jul 26, 2025 at 12:49 PM.
  1. Deadsmiley
    Deadsmiley Insider
    Bowling Green, KY
    When I pull in the clutch, I cannot start my 1998 VFR unless the bike is in neutral.
    It doesn't quite push the switch in far enough by about 1mm.
    I have aftermarket, adjustable levers.
    I have stock levers.
    I have replaced the aftermarket levers with different aftermarket levers.
    I have replaced the switch with an OEM Honda switch.
    Nothing has helped this issue and I am a bit stumped.
    I am open to suggestions, insults and curses. Lord knows I have had let a few of them fly while dicking with this. Thanks!
    just one suggestion: diode
  3. Deadsmiley
    Deadsmiley Insider
    Bowling Green, KY
    Can you expand on this? I know what a diode is, not sure how it applies in this case?
  4. squirrelman
    one-way path to ground, logic circuit, switch on/switch off. service manual shows location, check it with a test meter. cheap to replace.
  5. Deadsmiley
    Deadsmiley Insider
    Bowling Green, KY
    The switch on the clutch works. I can push it in a tiny bit more and I can start the bike when not in neutral. It just doesn't get pushed in far enough with any levers I have, including the stock lever, which is very weird. The previous switch worked as well, but had the same issue.
    I am thinking it has to be something mechanical with that lever or the lever hardware.
  6. squirrelman
    carry on
    Deadsmiley likes this.
  7. Deadsmiley
    Deadsmiley Insider
    Bowling Green, KY
    I think just talking about it here has led me to thing about this a bit more.
    Thank you for being my sounding board.
