Clutch issue--not disengaging
Discussion in 'General VFR Discussions' started by adamjenkins, May 25, 2010.
  1. adamjenkins
    adamjenkins New Member
    Massachusetts
    My 1990 Vfr appears that the clutch is not disengaging. I checked the slave -works fine- Removed clutch cover -checked clutch movement. ok I inspected the clutch rod -fine Checked for air in clutch line..fine
    When it is on the stand and you put it in gear (clunk) --you cannot turn the wheel -pull in clutch and still cant turn the wheel ???
    Any input
  2. captb
    captb New Member
    Did it sit for a long time?
  3. TOE CUTTER
    It is the first thing that comes to mind. Are they just stuck together?It happens.
  4. adamjenkins
    Massachusetts
    I have been searching the web and that may be it, The bike has been sitting while I am waiting on parts.....see----- pushing my bike thread..
    I am going to do an oil change and hopefully I will have the parts for the rear hub this week,, cross your fingers..
  5. captb
    captb New Member
    In the past I just got it rolling running neutral clutch in put it in gear and hold the clutch in and blip the throttle.
  6. adamjenkins
    Massachusetts
    I think my biggest concern is when the rear hub assembly fell off while I was riding and if that may have damaged something.
  7. Ghost_Rider
    Ghost_Rider Active Member
    LA & Utah
    Not sure what you mean you did by "checked for air in the clutch line". Did you fully bleed the system? Sometimes air can stay trapped at the "banjo" bolts, and the only way to get it out is to crack them open ever so slightly.
