clutch fluid low, Leak at shifter / kickstand
Discussion in '5th Generation 1998-2001' started by adam3d, Aug 9, 2012.
Tags:
  1. adam3d
    adam3d New Member
    San Francisco, California, United States
    I'll post a pic asap, but I noticed my clutch reservoir was low, then noticed a build-up of oily goo all over my kickstand. (it coagulated before dripping onto the ground)
    Looks like a slow leak out of the clutch/shifter area. I have a VFR mechanically inclined friend who can help (since I'm not), but is this potentially a big & difficult fix?
    thanks!
    1998 5th Gen, 12K mi
  2. Apittslife
    Apittslife New Member
    Clarksville, Indiana
    Sounds like a clutch slave cylinder gone bad.
    Paul
  3. adam3d
    adam3d New Member
    Thanks Paul! I'll start there.
  4. Comicus
    Comicus New Member
    East Nashville
    I had the same thing happen on my 6th gen. I just pulled the slave cylinder apart and replaced the gasket and rubber seals. That took care of the problem. Cost about $10 in parts and you'll have to bleed your clutch. Air likes to hide on the banjo bolts and slave cylinder.
  5. adam3d
    adam3d New Member
    Thanks for the advice. Turns out it was a false alarm, and it was just a bunch of chain goo gunked up in that area. Phew!
