Clutch Fluid Leaking
Discussion in '1st & 2nd Generation 1983-1989' started by StuMayhem, Aug 25, 2007.
  1. StuMayhem
    StuMayhem New Member
    Middle of U.S.A.
    I replaced the slave cylinder gasket, spring, and the rubber washers. The fluid is coming from behind the left side cover. I can't really tell where. Any ideas? Could it be the gasket on th eother side of the crankcase cover?
  2. StuMayhem
    Middle of U.S.A.
    OK, so I took off the slave cylinder and the sprocket cover and replaced both of those gaskets. Put some fluid in, and it started leaking again immediately. Any ideas from anyone? '86 vfr750.
