Clutch Cover stuck
Discussion in 'Mechanics Garage' started by Lint, Apr 20, 2016.
  1. Lint
    Lint Member
    Simi Valley, Ca.
    I have triple checked to ensure all bolts are removed. I can't get the clutch cover to budge. Ideas?
  2. Y2Kviffer
    Y2Kviffer Insider
    RALEIGH, NC
    A plastic dead blow hammer, or a piece of soft wood like pine and a hammer. Tap don't slam...
  3. Lint
    Lint Member
    Simi Valley, Ca.
    I'll try it. I have the wood, not the plastic, rubber, nor hide hammer, although I used to own the latter.
  4. Marrib
    Marrib Insider
    Phx, AZ
    Clutch plate puller?
  5. squirrelman
    It's hanging on the 2 dowel pins, so you need to start loosening it up at their locations.
  6. Lint
    Lint Member
    Simi Valley, Ca.
    Mr. Squirrel,
    Never mind, my manual was opened to the page when I looked at it. I see them.
  7. Lint
    Lint Member
    Simi Valley, Ca.
    Got it off. I pried the to tab carefully with a big class hammer. Came right off.
  8. Lint
    Lint Member
    Simi Valley, Ca.
    Now I just need to figure out how to get all the old gasket off. It's really stuck on there.
  9. Y2Kviffer
    Y2Kviffer Insider
    RALEIGH, NC
    A dremel and a scotchbrite type pad.
  10. Terry Smith
    I got mine off gently with a wood chisel. Keep the blade as flat to the mating surface as possible and don't gouge the surface. Fill the open crankcase cavity with rags to catch the debris. Take your time.
  11. GigemVFR
    GigemVFR New Member
    TEXAS
  12. GreyVF750F
    GreyVF750F Member
    West of Cleveland Ohio
    A semi sharp single sided razor blade at about 30* to the surface or in a drag back motion straight up. In a blade scraper type holder is better. Can use chlorinated brake cleaner to soften.
    That's why I always permatex the gasket to the cover and then apply a very thin coating of grease to the mating side of the gasket. A lot better chance not leaving gasket on the engine vs the cover next time taking off. Which is easier to clean.
  13. Terry Smith
    What is the mating side of the gasket Mr Grey? I think I remember one side had writing and the other didn't, and there is only one way to install the clutch gasket.
    I do like the idea of a coating of grease on one face so that the gasket comes away in one piece next time.
  14. Lint
    Lint Member
    Simi Valley, Ca.
    He just means the side of the gasket that touches the engine case. It would be siliconed to the clutch cover, but have a grease film to prevent it from sticking to the case. I wish Honda had done this or at least greased both sides of it. Or even better yet, used a nitrile seal or the like. My gasket is stuck un like someone epoxied it. Massive PITA to remove!
  15. Gator
    Gator Member
