Clock Reset at Start-up
Discussion in 'Mechanics Garage' started by Wu-Viffer, Jan 13, 2008.
  1. Wu-Viffer
    Wu-Viffer New Member
    San Francisco, CA
    I am having this intermittant problem where my clock and trip-odometer will sometimes reset as if they have lost power when I start my motorcycle. Anyone else had this problem?
    2001 VFR
    Thanks,
    Mel
  2. eddievalleytrailer
    eddievalleytrailer Member
    Jonesborough, TN
    Sounds like a bad battery connection or a weak/bad battery.
  3. Wu-Viffer
    San Francisco, CA
    I guess you just check it with a voltmeter at start-up and see if there is enough juice?
  4. eddievalleytrailer
    Jonesborough, TN
    You could watch a voltmeter while cranking. If it drops below 10v, recharge then check again. If it still drops below 10v while cranking (and after cleaning connections), I'd have the batt tested with a load tester or just replace it.
  5. Wu-Viffer
    San Francisco, CA
    Thanks for the suggestions. I'll put a voltmeter to it tomorrow at work.
    Mel
  6. hatzyian
    hatzyian New Member
    Larnaca Cyprus
    Before you replace the battery, check all the conections, they can cause voltage drop as well.
  7. powderrecon
    powderrecon New Member
    Seattle
    Also, if you are about do the replace battery route, check the R/R first. It might be fried.
