Cloc Question 3rd Gen (90)
Discussion in '3rd & 4th Generation 1990-1997' started by green1, Jun 27, 2009.
  1. green1
    green1 New Member
    I just bought a clock for my 3rd gen and am not sure if the harness has the connector for it.Does anyone know if all 3rd gens have a female connector on the harness if the bike didn't originally come with a clock? Or does someone know where the clock is supposed to plug in,there is an empty space behind the cluster where most of the other connection are held,thanks in advance.
    Answer is yes,had to remove the upper fairing to gain access but its there.Clock was just bolt on and plug in
  2. SA1713
    SA1713 New Member
    There should be a female plug already on the wire harness just for this clock. Pull the nose cone off (I know, PITA) and look behind the instrument cluster. It should be right there.
  3. green1
    green1 New Member
    Yes it was there,i posted the question,waited a wkile then said f-it and took the upper fairing off.It was there,thanks for the reply
