Cleaning the sprocket
Discussion in 'Mechanics Garage' started by SFPA, Dec 20, 2006.
  1. SFPA
    SFPA New Member
    Fayetteville, NC
    Anyone out there have a cool trick for getting all that used PJ1 off the rear sprocket... Aside from good ol' elbow grease (which I used alot of last night).
    Assuming most de-greasing sprays will damage the delicate innards of the chain....
  2. Action
    Action New Member
    Albuquerque
    Try using a little of whatever you use to clean the chain with. I spray a little WD-40 on to a rag then use a finger tip to wipe it off. Greased Lightning works well to clean chain fling off the inside of the rim.
  3. chesthing
    chesthing New Member
    Colorado
    I use Maxima degreaser (safe for chains) and Honda spray lube and the chain looks like new.
  4. KC-10 FE
    KC-10 FE New Member
    DID (OEM on 90% of Honda's) recommends cleaning the chain with kerosene & a soft bristle brush. I use a old Reach toothbrush. Put a large cookie sheet or tin foil to keep the mess off the garage floor. I pat/rub the chain dry with a lint free rag. I then use the Honda spray lube in the red & black can or BelRay. I've been using this method since day one & my chain looks brand new.
    KC-10 FE out...
    :plane:
  5. SFPA
    SFPA New Member
    Fayetteville, NC
    Awesome, fellas, thanks. FRIENDLY and helpful replies...a breath of fresh air!!
    Merry Christmas!!
  6. KC-10 FE
    KC-10 FE New Member
    I forgot to add, DO NOT let Grease Lightning touch ANY Aluminium on your bike that is not painted. You will not like what happens if you do.
    KC-10 FE out...
    :plane:
