Choke Clamp and Screw
Discussion in '1st & 2nd Generation 1983-1989' started by fatso1277, May 6, 2011.
  1. fatso1277
    fatso1277 New Member
    South Suburb IL.
    Does any one know where i can get a clamp that holds the Choke Cable to Carb and screw that goes into it.
  2. TOE CUTTER
    I think I can help oot with that one.........send your info and I will send it oot.
  3. fatso1277
    South Suburb IL.
    PM SENT..Thanks alot
  4. TOE CUTTER
    LOL!!!!!!! It IS THE VERY LEAST I can do.
  5. elysse
    elysse New Member
    Lexington, Kentucky
    Also, for future reference, here's what I did for my missing clamp situation before I got replacement carbs (long story short, the carbs on the bike were abused):
    I used a 428 master link top and bent it into roughly the right shape, et voila. It's by no means an elegant solution, but I did find it worked quite well. I also used a (I think) 4mm screw that I picked up from the hardware store.
    As these things go, when I got the new set that blessedly still had the choke clamp assy still in place I found my original choke clamp on the top of the bottom end in the 'V'. Who knows how many hundreds of miles it rode there..... definitely look there if you're missing yours. :-D
