checking my FI codes??
Discussion in '5th Generation 1998-2001' started by hondajt, Jun 15, 2009.
  1. hondajt
    hondajt New Member
    springboro, oh 45066
    Well as I have complained about many time, our search engine will not let me search for FI codes, or CEL.
    So, my bike is running funny, and the FI light is coming on/off. How do I check the codes?
  2. 02 VFR Rider
    02 VFR Rider New Member
  3. hondajt
    hondajt New Member
    well, mine blinked, 41 times, before I just turned it off. And watching that video, I've realized it was just blinking once, and repeating.
    So:
    1.) loose or poor contact's on the MAP sensor.
    2.) open, or short circuit in MAP sensor wire.
    3.) Faultu MAP sensor.
    This sucks.
  4. hondajt
    hondajt New Member
    How do I drain my Fuel tank quickly? I need long term access to my air cleaner, and my tank is nearly full. Which line can I pull, to let the gas out?
    The manual doesn't mention much, just the fuel return line, but no other comments I can find....
  5. 02 VFR Rider
    best to pick up a siphon hose to drain tank.
    attach it to a piece of threaded rod w/ a few zip ties to get to the bottom of the tank.
    there is no fuel shut off ( well on 6th gen ) and as soon as you disconect the fuel line gas goes every where.
  6. hondajt
    hondajt New Member
    thanks. I think theproblem is with the wiring near the ECU now, but am unsure.
