Charger for Battery
Discussion in '6th Generation 2002-2013' started by dohsar, Dec 16, 2010.
  1. dohsar
    dohsar New Member
    I got a 02 VFR 800 with a little charger element on the side out of the fairing. Where can i get a trickle charger to hook it up?
  2. tinkerinWstuff
    :worthless:
  3. OTTOMAN
    OTTOMAN New Member
    Olympic Peninsula, Wa.
    Just guessing here but most commonly this would be a two pin flat connector, one pin is bare while the other is enclosed in the same covering as the the connector. If this is what you have, it's universal for a Battery Tender brand float charger/maintainer. Available at any MC store and most sporting goods departments of variety stores.
  4. Africord
    Africord New Member
    Nebraska
    Charger Suggestion
    I use the DieHard motorcycle charger I bought at Sears with no issues. Hooks right up to a Battery Tender connection. For some of us, that may be easier to work out. Motorcycle shops in my area keep pretty weak hours, or I work too much!!
  5. tinkerinWstuff
    plugs can be found at your local auto parts store.
  6. woobie
    woobie New Member
    Beamsville, Ontario
    What ever you do make sure you get a charger that shuts off when the battery is full. Some cheap ones will just keep charging away and fry your battery.
  7. Lgn001
    Lgn001 Member
    Russian River by Ocean, CA
    I hope this doesn't sound too obvious, but check the existing bike plug with a voltmeter; don't trust the wire colors (assuming that it has different colors). There is never any telling how it was hooked by the previous owner. If is a heated apparel connection, it might even be relay-switched by the ignition being on or off, which means that it can't be used for a trickle charger anyway.
    If you read voltage (~12.8) with the key off, it will work.
