Changing the Front end VFR800 Vtec
Discussion in 'Mechanics Garage' started by natalie, Aug 29, 2007.
  1. natalie
    natalie New Member
    Hello,
    I am in the process of doing up my bike.
    It was a standard Blue VFR800 Vtec 2002
    Now i have painted The frame swing arm, fairings Black with red Fleck and change everything i can find to change.
    I Really wanted to change the front end to a CBR1000 or something like that but after Hours of oulling down and trying it just didn't fit.
    I once ran into a VFR owner that had done it to his bike, He said he put in a HOnda vtr1000 SP1 front end. So i checked one out and dont see how that will work either.
    If anyone has any ideas or has seen this done i would love to know.
    Once my bike is complete i will post the pics up..
    Thank you
    Natty,
  2. Rogue
    Rogue New Member
    Hi, go to vfrdiscussion.com and search for frankenviffer..all will be revealed.
    Rod
  3. fotomoto
    fotomoto New Member
    South Texas
    I put a cbr600rr front end and a vtec rear on my 4gen. Yeah, it's not a bolt on but it wasn't that difficult (hey, I did it!). Although on a vtec you'll be losing one of the best headlight systems out there, if that matters to you. Unless you want to tackle redesigning the cooling system, I'd say stick with the RC51 bodywork to keep using the side rads.
  4. natalie
    natalie New Member
    Wow that looks awesome,
    Thanks guys
  5. hondawolf
    hondawolf New Member
    Livermore, Ca
    Wow, looks great! Good work. Is it much work matting up to the headstock on the frame? Was it mostly bolt on parts, or some machining required to do the front end?
  6. rode2rouen
    rode2rouen Guest
    Over the coming winter I'll be in the garage putting RC51 SP2 forks on my '02.
    I've collected most of the needed bits, (Ebay is a great resource) so it's just a case of waiting for the weather to get chitty.
    It is essentially a bolt on if you use CBR929 triple clamps as they use the same head bearings as the VFR.
    Rex
  7. John451
    John451 Member
    Check out OzVFR.net ( when it is fully back ) , zROYz performed the SP front end mod on a '04 VTec, must say it looks fantastic the SP Front end is currently on a SuperBlackbird when he intended to sell the VFR but he wants it back on now he has decided to keep it again.
