changing a 5th To 6th
Discussion in 'General VFR Discussions' started by Bigherm2121, May 17, 2010.
  1. Bigherm2121
    Bigherm2121 New Member
    Pittsburgh
    Does anyone know if its possible to change the ass end on a 5th generation to a 6th generation? I like the 6th way better then the 5th. Just wondering.
  2. jethro911
    jethro911 Member
    Merrickville, Ontario Canada
    That is a good question!
    I know the sub frames are completely different but that is where you need to start by adapting the 6th gen subframe and then hang everything on it. I can get you some pictures of my sub frame when I get back home this weekend so you can compare it to the 5th gen. There may be some pctures in the gallery that could help.
    It would require relocation of a few items like the rear brake reservoir and the RR unit as well as the battery and ecu etc but with some creativity and craftsmanship I would think that it could be done.
  3. 02 VFR Rider
    02 VFR Rider New Member
    someone on VFRD has done it to add the undertail exhust.
    do a search on VFRD you should find it easy
  4. vfrcapn
    vfrcapn Member
    Grass Valley, CA
    I think that vfrd bike was a 4th gen with the 6g tail. It certainly can be done with some work.
