Center stand option on 91??
Discussion in '3rd & 4th Generation 1990-1997' started by thorrinn123, Feb 25, 2009.
  1. thorrinn123
    thorrinn123 New Member
    Was a center stand ever a option on a 91-93? I had heard somewhere that bikes in canada could have a dealer option put on? I am looking to acquire one but want to make sure it is going to even fit.
    Thanks,
  2. Badbilly
    As I recall a centerstands on the 91's were an "option" Meaning more bucks. Mine fits fine, It took two of us to install it and never a problem.
  3. thorrinn123
    so...
    it is just a matter of installing it....there is a place that it goes without any cutting or modifications?
  4. Craig in Alabama
    Craig in Alabama New Member
    Madison, AL
    centerstand
    I added a centerstand to my '93. The brackets and everything were already in place and it was a straight bolt-up situation.
    To make it easier to deal with the springs, put pennies in the coils during installation and take them out when you're done.
    Cheers!
    Craig :smile:
  5. Badbilly
    Yep, your bike is ready to go. Good stuff on the use of coins we used washers and lots of colorful language.
    There are several places on the net where the frame and perches are shown. Factory manuals are good things to have at hand.
  6. thorrinn123
    do you know offhand where i can find pic of the frame and perches i tried to do a search and didn't find anything.....and when you mean put pennies in the coils you mean stretch out the spring coils and insert coins in and release???
  7. Craig in Alabama
    Madison, AL
    Don't know about the pictures, but you just slide pennies, or washers, in between the spring coils, effectively stretching the spring, which makes installation much easier (or even possible). They'll fall out the first time you use it.
    Craig :smile:
  8. Badbilly
    Centerstands on 91's were an option as were seat cowls.
    The service manual for 90-93 VFR's is in PDF and downloads in just minutes. It's a freebies. The frame is made to accept the centerstand.
    The coins a/o the washers are used as spacers. The spring is one badass spring.
  9. thorrinn123
    i have the service manual in pdf i will have to look at it to see if it show where it would go and such.....thanks for all the help......if i have the bike up on a bike jack will i still be able to install it or will the jack block the are needed??? how did you do your install when you did yours?
  10. Slothrop
    Slothrop New Member
    northern lower Michigan
    When I got my '96 the centerstand was off. I put it on with the bike on the sidestand; only took a few minutes to do. Dunno if yours will work the same way.
  11. rychas1
    rychas1 New Member
    atlanta
    my 90 has one. not sure if it was added or factory option.
  12. thorrinn123
    any chance someone can take a pic of how it is attached?
  13. Trize007
    Trize007 New Member
    Smyrna, GA
    My 93 has a center stand. When I put it on the lift it blocks it from coming down. Like Slothrop stated above try to do it while its on the side stand. Or get someone to hold the bike up right while you install it.
  14. thorrinn123
    Trize007 could you take a pic of how it is attached?
  15. Trize007
    Trize007 New Member
    Smyrna, GA
    Sure... Will do it this evening when I get home from class.
  16. thorrinn123
    that would be great will help me locate on how to put in on and such...as the service manual doesn't cover 91-93 for a center stand.
  17. jay956
    jay956 New Member
    Richmond, Virginia, United States
    i just got my 93 a few months ago, the center stand wont fit on it because of the TBR exhaust system on it, but the seller gave it too me along with the other stock parts. if your interested i might sell it.
  18. thorrinn123
    jay956 i would be interested!
  19. Badbilly
    Page 221 of the service manual shows the centerstand.
    These were options as were the hard to find seat cowls. Like many of the instructions in a service manual there is no step by step instruction on installing or removing a centerstand.
  20. thorrinn123
    that is for bikes after 93.....badbilly....94-
