Cdi locality
Discussion in 'Mechanics Garage' started by VFR2fasr4u, Jul 21, 2020.
  1. VFR2fasr4u
    VFR2fasr4u New Member
    87 700 interceptor ,is cdi box under seat in the back over tail light?
    in a word.......yes.
    but u need to remove (loosen) the sub-subframe and lift it it slightly for clearance to get cdi forward AND OUT and also a screw on a small cover.
    why r u needing to fuss with it ?
  3. VFR2fasr4u
    No spark and just to know thanks for all input
    .I just found out that the kill switch might have little to do with it.the bike sat in rain for years jjust trade ninja600 for vfr 700 want to see if it runs
  4. squirrelman
    you won't learn much unless u have another cdi to substitute, but u could clean connection plugs.
  5. VFR2fasr4u
    I learn just that thanx for the info I found out that the on off switch can loose contact .that my next move .
  6. squirrelman
    with a multimeter you can check the switch continuity at the plug connection. another test would be to check for battery voltage at the blue/white wire in the 6-pin cdi plug. also test that the green wire there is connected to ground.
    if stop/run switch is bad, no voltage to cdi.
    dhinson66 likes this.
  7. VFR2fasr4u
  8. VFR2fasr4u
    Thank you I'm liking the information I get here at VW I will do just that next I think we might fig it out
    Thanx for your help I figured it out ☺️
  9. VFR2fasr4u
    Without it is a never got it
  10. VFR2fasr4u
    Ya just to be clear your info helped me to figured it out
  11. squirrelman
    pleased 2 help.
    was it the switch ?
  12. VFR2fasr4u
    Fur sure and the whole circuit really.Big help on another note, who makes fairings for 87 vfr 750/70?
  13. squirrelman
    nobody. you're up shit's creek on that one. :( bike looks muscular and strong without fairings, but they show up on ebay about twice a year.
