Im having a problem with my cct rear on installation, i removed it and placed two extra turns on the plunger as per the you tube videos, on installation the plunger is contacting the cam chain slide .2 of an inch before being fully seated, from the cct mounting face to the tip of the plunger measures 1.6 inches, so either the plunger is not fully retracted or the cam chain slide has moved, i am retracting the plunger what appears to be all the way. any suggestions out there? howard. 2003 interceptor
