CBR Wheels for VFR
Discussion in '1st & 2nd Generation 1983-1989' started by rjrcmr03, Apr 11, 2010.
  1. rjrcmr03
    rjrcmr03 New Member
    Will 92 CBR600 f2 wheels fit on my 86VFR700?
    The tire and wheel size on the CBR are front 120/70zp17 and Rear 170/60zp17
  2. matt1986vf500f
    matt1986vf500f New Member
    Lula, Georgia, United States
    yes sir they will. use the search fuction and you will find threads where people have done it, i can tell you this much that the front wheel rotor stabs needs to be machined to fit between the forks
  3. supertex
    supertex New Member
    The actual answer is yes with some modification or in combination with other parts. You can't use either as is, with no modification to the bike or the parts. A Hurricane front wheel will fit, but theres little benefit in doing that. The front usually is done only with the front end being replaced with the same F2 pieces. The rear is easier with just the spacers and brake calipers needing to be replaced.
  4. TOE CUTTER
    The best mod you can make to a gen 2.
  5. Yonan
    Yonan New Member
    TURLOCK, CA
    With some work and cash yes and this it what it will look like.
  6. Massimo
    Massimo New Member
    Hi there! I bought a VFR700F2 (87) a month ago and I noticed that the rear brake pads/caliper where 1/2" off. I then realized that PO changed the Rim but not finished the job by changing the rotor or the caliper holder.
    Anyway, any suggestions on which are the proper mods options I have? The wheel is 17x4.5, 6 spokes, 4 holes for the rotor and has a smaller rotor, the rest is original.
    Thank you!
    PS: Yonan, love your 1986 VFR750F! Mine is the white 87 and I also have an 89 Transalp with that color scheme, I wish could've gotten yours to match ;-)
