i am disassembling the carbs on my '83 vf750. i've gotten everything apart except the 'jet needle holder' and the 'starter jet'. these are round and i dont know how to get them disconnected.... can someone tell me how? OR- can i leave them in when i soak the carb body (will the clean ok installed)?
Fsm ?? Those 2 parts are not removable, which you'd know if you studied The Book. You should be able to blow air into the lower brass tube; use wire to unblock it if necessary.
