Carb swap question!
Discussion in '1st & 2nd Generation 1983-1989' started by ic2283, Aug 26, 2010.
  1. ic2283
    ic2283 New Member
    i came upon a 1984 sabre v45 for 200 and I want to swap the carbs from that into my 1984 vf700f interceptor. is this even possible because the air filter system is different? The sabre carbs/air is wayyyy smaller then the interceptor's carb/air set up. I know that the interceptor has a fuel pump but beside fabbing up a few things onto the frame it should fit. any help??
    i doubt it could be made to fit, but why do you want to swap ??
  3. TOE CUTTER
    This question has come up many times, curious myself if the manifold could be changed.
  4. ic2283
    ic2283 New Member
    I wanna change cause I can't find the damn fuel joint!
