Carb Rebuild Kits 1990 VFR?
Discussion in 'Mechanics Garage' started by pgafuture, May 10, 2010.
  1. pgafuture
    pgafuture New Member
    Hampton, New Jersey, United States
    Hello. I'm new to VFRs just bought one and got it home. I've got the Air box off and I'm down to the carbs. Where do I find a carb rebuild kit? Also any cheap starter motors out there? thanks.
  2. captb
    captb New Member
    I did more than it probably needed... float valves (needle & seats) new bowl o-rings and fuel tee o-rings all for $55.....I wanted to be sure of no leaks since I spent extra $$ to make it showroom condition, I've seen a few old bikes burn to the ground over a 0-ring seal.
    Here's some other sources CALL THEM if they don't list it.
    http://www.z1enterprises.com/catalog.aspx?pid=HPCF0
    http://www.carbkitscapital.com/carb_kit_parts.php?make=Honda
    http://www.crc2onlinecatalog.com/Index_Main_Frame.htm
    https://www.partsnmore.com/cat_index.php?model=V45&category=carb
    http://www.v4market.com/
  3. pgafuture
    Thanks for your input. Was that per carb price?
  4. captb
    captb New Member
    I didn't get kits, I wanted to keep as many oem parts as possible (4)float valves $30 shipped from V4 market, bowl seals (4) for $23 fuel tee o-rings from a major o-ring supplier in town $2
  5. pgafuture
    It turns out that the fuel pump and filter were missing from my bike. I'm thinking that when these parts arrive I may not need to clean the carbs. I have sitting here with me, new gaskets and o rings for the carbs. I'm thinking I should run some seafoam and test the bike before I dig into the fuel system. I've cleaned the tank and replaced fuel lines already. Does this seem like a good plan?
  6. squirrelman
    Good plan, yes: Test before making assumptions.
