Carb plugs
Discussion in '1st & 2nd Generation 1983-1989' started by ThatVF500Guy, Mar 22, 2013.
  1. ThatVF500Guy
    ThatVF500Guy New Member
    Atlanta, GA
    Doing some cleanup on the carbs. I found the source of a vacuum leak where it looks like it was "repaired" with jb weld. I can fix it the same way but I would rather use the plugs. Is there a source for these? I've searched the usual places such as McMaster but so far I have not found any.
    There are two spots but you can see where the vacuum leak is.
    Thanks,
    Jim
  2. ThatVF500Guy
    Atlanta, GA
    Gave up on the plugs. It looks like the PO drilled a hole in the disc/plug and pulled them out. I have no idea why unless it was to swap in a different carb. Anyway, I cleaned up the old discs and reinstalled with a new coat of JB weld. Problem solved.
